Help with parts!
4 Jan 2014
Hi guys,
Building a PC hopefully in April.
I have these parts and I need help building the rest around it:
AMD FX-8350 Vishera 4.0GHz <----- CPU
MSI R9 270X <----- GPU
Team Vulcan 8GB (2x4GB) <----- RAM
£300 Budget! or as close to.
Thanks Guys!
Note: you have to think how much they will charge to import it and customs.
Its best to order it here, yeah maybe its expensive but you will probably save more money from shipping and custom.
So that build is going to be in April? can't you save more money and possibly wait for whatever new hardware is coming out this 2014?
Edit: Oh and shipping it back if you need to return it or warranty.
I'm going to America in April so the shipping and customs won't be a problem.
Those are the parts I have so I'm basically asking for:
Motherboard
Power Supply
Cooling Unit
Easy to do if I've read this correctly (you've got £300 left, right?).
PSU, Motherboard, CPU Cooler, Hard Drive, Optical Drive and Case.
YOUR BASKET
1 x Asus M5A97 EVO R2.0 AMD 970 (Socket AM3+) DDR3 Motherboard £79.99
1 x Toshiba 2TB 7200RPM SATA 6GB/s 32MB Cache - OEM (DT01ACA200) HDD £59.99
1 x SuperFlower Golden Green HX 550W "80 Plus Gold" Power Supply - Black £59.99
1 x Corsair Carbide 200R Compact ATX Case - Black (CC-9011023-WW) £47.99
1 x Alpenföhn Matterhorn Pure Edition CPU Cooler £29.99
1 x OcUK 20x DVD±RW SATA ReWriter (Black) - OEM £16.99
Total : £304.54 (includes shipping : £8.00).
I may have a case locked down from my brother, It's a Advent Centurion case.
I should've been more clear I apologise:
I have a CPU
I have a GPU
I have a Case
I have some RAM
I have Hard Drives
and I have Disk Drives.
All I need is a MotherBoard, a Power Supply and a Cooling unit with £480 or so due to the fact i'll be getting the parts in America
I have a CPU
I have a GPU
I have a Case
I have some RAM
I have Hard Drives
Do you plan to OC at all?
water cooling maybe?
http://www.overclockers.co.uk/showproduct.php?prodid=HS-015-CS&groupid=701&catid=2330&subcat=2262 or you can get something lower if you don't want to OC.
Nuctuas are good as well there are many reviews on google and youtube.
Edit: Sorry I should have just added it to my above reply.
Ohh right, I doubt they will explode imo. I've been running a single radiator for 4years now from Corsair.
Maybe try reading or watching some reviews about noctuas heatsinks if you want something good air cooler and quieter.
