Help With PC Build - Gaming Machine
Status
Not open for further replies.
7 Apr 2015
Hi Folks,
I'm new here and looking for some help/advice on building a gaming machine. My budget is going to be between 600-750 and it would be greatly appreciated if some of you folks out there more in touch with the latest on hardware to build my machine for me, or provide options/builds you think is best for my budget.
I was going through the config myself messing about with it and came up with this, what do you guys think?
Standard Build Systems - Dispatched within 7 working days
- No Security Software
- OcUK Value AT/ATX "Kettle Plug" 2 Meter Mains Cable
- Gaming Chair Not Selected
- No Headset Option (Zero Cost)
- Speakers Not Selected
- Monitor Not Selected
- Mouse Not Selected
- Keyboard Not Selected
- Case Mods Not Selected
- Networking Not Selected
- No Operating System
- SuperFlower Golden Green HX 450W "80 Plus Gold" Power Supply - Black
- NO OPTICAL DRIVE INSTALLED
- Seagate Barracuda 1TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD
- Kingston 120GB SSDNow V300 Drive SATA 6Gb/s 3 2.5" (7mm height) Solid State Hard Drive - (SV300S37A/120G)
- Sapphire Radeon R9 280 Dual-X 3072MB GDDR5 PCI-Express Graphics Card
- Kingston HyperX 16GB (2x8GB) PC3-14900C10 1866MHz Dual Channel Kit - Black/Red (HX18C10BRK2/16-OC)
- No Upgrade - Intel Stock Cooler (None overclocked systems)
- Asus H81M-PLUS Intel H81 (Socket 1150) DDR3 Micro ATX Motherboard
- Intel Core i5-4690 3.50GHz (Haswell) Socket LGA1150 Processor - Retail
- BitFenix Neos ATX Tower Black/Black
Regards,
Stevie
Status
