Hi all,
So I'm upgrading from an Alienware X51 as I'm now using Triple XL2420XT Monitors and need to SLi to get the performance across all screens that I am after.
So what I've decided on,
YOUR BASKET
1 x EVGA GeForce GTX 670 FTW 2048MB GDDR5 PCI-Express Graphics Card £319.99
1 x NZXT Phantom 820 Enthusiast Full Tower Case - White £199.99
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £179.99
1 x OCZ ZX Series 1000W '80 Plus Gold' Modular Power Supply £159.98
1 x GeIL EVO Corsa 16GB (4x4GB) DDR3 PC3-17000C10 2133MHz Quad Channel Kit (GOC316GB2133C10AQC) £99.95
1 x Phanteks PH-TC14PE CPU Cooler - Orange (Socket 775 / 1155 / 1156 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2) £69.98
Total : £1,047.59 (includes shipping : £14.75).
I also already have HDDs and an SSD to chuck in it.
What I can't decide on, is the Motherboard and the Heatsink. I was looking at the Phantek's Cooler as I've read good things about it.
What would you suggest? I don't want it to block the PCI-e Slot, which seems to be a common problem with big heatsinks. Do you have any recommendations on the board I should use with the Heatsink + Sli. I will be looking at going Triple SLI next month and an Revo Card, hence I spec'd the 1000w PSU.
Also, what RAM would you recommend?
My budget is around £1400 all in.
Any advice?
YOUR BASKET
Any advice?
