help with pc optical out crackle
18 Feb 2013
hey!
hopefully this is the right place to ask.
I just picked up some desktop speakers ( Ruark Audio mr1 mk2).
I have them connected to the optical out on my tv ( samsung qn90b )
With my ps5 everthing is fine. However when I'm connected to my PC ( hdmi to tv ) the audio will cut in and out. When listening to music via youtube its not so often, but still happens ( when im on the web ).
When im playing a game, it keeps dropping in and out, every couple of mins.
Any ideas how to fix this? I figure its to do with something loading.
Thanks!
Not 100% sure if this will give you a solution but you can try this.
On your PC go into Settings>System>Sound>More sound settings
Find the Optical Out or your Sound Card under the Playback tab
Click Properties>Advanced and then change the default format to 16bit 48khz (DVD Quality) and see if that makes any difference
I know this was like 2 years ago BUT THANK YOU. I had started getting this crackle on explosion noises and it seems like at some point the default format had changed.
