Help with PC spec
28 Nov 2005
Scotland
Hi all,
Looking for some help/pointers.....
Looking to spec up a new system that will predominantly be using for running VMs and music processing, therefore RAM (more the better) and CPU is the priority. I don't do any gaming so graphics is not an issue.
I've got a budget of £1,000 which does not include case, monitor or OS.
I've always had AMD, but not sure if Intel is the way forward these days?
Any help is appreciated :-)
with youre budget I would look at an intel build.
what case are you planning on using? as this would help for motherboard choice
