Help With PCI Express x1
6 Jan 2007
Hi All
I have an Asus P5VDC-MX motherboard that needs a graphics card
it has PCI Express x1 & AGP 8X (1.5V)
What cards would be the best for it to the cost of about £50
Also can I fit any PCI Express card in it are they all compatible, Will I be better off with an AGP card.
Hope you guys can help
Regards
Dex
I used an AGP graphics card HD3650 from Sapphire which was quite capable, drivers can be a pain with AGP though. Oc have some new AGP cards, for about £50 you can get,
http://www.overclockers.co.uk/showproduct.php?prodid=GX-023-HS&groupid=701&catid=56&subcat=1842
PCI-e x1 graphics performance can be low on bandwidth, dependant on length of slot, I have heard you can fit any card by removing the back of the slot, but I have no 1st hand experience or knowledge of this practice.
Is it revision1 or x1 pci-e?
PCI Express help
Cheers guys
I think I will buy an AGP card
Whats the best AGP card at the moment
Do I need a 1gb card, I do use it for games a little.
Dont want to spend a fortune, I did see some sparkle 1gb card on ebay but it looks like its from the US.
Cheers again for the help
Dex
