I recently started using DokuWiki with the Monobook template and am having some problems with my PNG logo in the top right. Every time a page loads it will be non-transparent/grey where it should be transparent for a few seconds until the page finishes loading.
I'm using IE6 (have to be, im afraid) and know there is an issue with PNG transparency but wasn't sure if this is the same thing. The site is here:
http://www.richl.com/gpt/ooold/
If you refresh the page or move to a different page etc i see this for a few seconds until the page finishes loading:
After which it looks normal, like this:
Can anyone help?
Edit: by the way, i tried the PNG transparency JS fix but it didn't make any difference for me. I assumed this wasn't the issue as the PNG's aren't always not transparent...just until the page finishes loading! I know it can be done as for some reason the MediaWiki install with Monobook template and my same little logo works perfectly. I used the same HTML from Mediawiki but didn't have any luck so assume there must be more to it than that...
Can anyone help?
