Help with possible laptop purchase
9 Jan 2009
Stoke On Trent
May be a no brainer but ill ask anyway - Looking into a laptop for games, not super expensive probably around the 5-600 range - Obviously dont have to be at full spec, Ive got a desktop for that (Mainly so I can lounge on Skyrim/WoW in comfort) Ive found two candidates so far.
Looked up a benchmark for the CPU and GPUs for them both and one has a substantially better GPU but the others CPU is better, at least, I think thats what im reading.
Wondering if I can get some guidance on the matter.
One is an Acer Aspire V3-571G spec is
£550ish
Intel Core i5-3210M 2.5GHz
8GB RAM
750GB HDD
NVIDIA GT 630M 1GB
the other is
Asus K55VD
£600ish
Intel Core i7 3610QM 2.3GHz
4GB RAM
500GB HDD
NVIDIA GeForce GT610M 2GB
So if im reading things correctly its either better memory and graphics for a lower cost, or a fancy i7 quad and compromise on the rest for more money.
Is there much difference performance wise all around or shall I just go with the cheaper one? Both laptops are 15" and a 1366 x 768 screen.
Cheers
£550ish
8GB RAM
750GB HDD
NVIDIA GT 630M 1GB
the other is
Asus K55VD
£600ish
4GB RAM
500GB HDD
Cheers
Asus N55SL might be a better option, has an i7, 6gb ram, GT635m, bluray and 1080p screen for £600.
The Gt610m might be a bit low for skyrim, however the processor is way better on the asus. The i5 is probably enough for those games though.
