help with problem please
28 Jun 2009
Hi when I switch on my comp the screen is covered in some pixels but continues to load to windows and then crashes and blue screens for a few seconds. Then it comes up with start windows normally ect, I hit it and it loads up fine.
windows comes up with this message then, but the comp works fine after that it only happens when I first switch it on.
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.0.6001.2.1.0.768.2
Locale ID: 2057
Additional information about the problem:
BCCode: 116
BCP1: FFFFFA8007B7B010
BCP2: FFFFFA600241A6A0
BCP3: 0000000000000000
BCP4: 0000000000000002
OS Version: 6_0_6001
Service Pack: 1_0
Product: 768_1
Files that help describe the problem:
C:\Windows\Minidump\Mini110909-01.dmp
C:\Users\Admin\AppData\Local\Temp\WER-30560-0.sysdata.xml
C:\Users\Admin\AppData\Local\Temp\WER7A0F.tmp.version.txt
Read our privacy statement:
http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
my comp specs are
intel core 2 quad 2.66ghz @ 3.20
gigabyte GA-EP45-UD3LR intel p45 pci-express DDR2
seagate barracuda 7200.12 500g sata-II 16mb cache OEM
corsair xms2 4gb DDR2
700w ps
ATI radeon HD 4890 1024mb GDDR5
vista basic 64
I just got it repaired by UKOC for a damaged case in delivery the interesting thing is that my graphics card is not the same one it looks different but it’s the same model, I’m not sure if that matters.
Any help much appreciated
You get a blue screen and then it recovers and you can start Windows?! (Without having to reboot?)
Something sounds pretty screwed there.
I would be checking my hardware. Run MemTest for RAM, check temps on CPU/GPU. Check connections.
Also try updating graphics drivers (as posted above).
