Help with PS action - change ppi?
20 Oct 2002
London
Quick question. I have an action that I use on my processed images that resizes them using 'fit image' and does a little sharpening. I use it to resize them to a 1024 box for uploading to Flickr/FB etc.
I've just realised that my action keeps the dpi/ppi (:confused: ) as 300 which is rather unnecessary. I want to change this to 72 but I'm having trouble doing it. If I record a new step using the 'image size' thing I seem to get blurry images. I don't think it recognises that I want the size of the image to stay the same (even if I put in 100 percent) and just change the ppi.
Can anyone help? Or maybe I should keep my images at 300ppi? What does everyone use for Flickr? :)
I thought PPI didn't matter unless you were directly printing the picture? 900px is going to be 900px on the screen no matter what PPI is used.
Hmn I think I got myself a bit confused. Doing the resizing within an action didn't seem to work. If I change the PPI manually and ensure the image size stays at 100% it obviously doesn't change anything as you say. My question then is, why do images off the web come in at 72ppi? I guess it doesn't matter but.. :confused:
When veiwing images on your screen the true ppi of a downloaded image is given by the resolution/size of your screen. You can calculate this by measuring the size of the image with a ruler and dividing the size in pixels by this number.
All if this is of course totally pointless.
PPI information is only used to ensure images are printed at the correct size.
EG. A 600*400 pixel photo printed at 600PPI will be one inch wide.
You could set it to 1000 PPI, and it wont make a difference on screen.
Well, not at least until we get true resolution independent screens and displays with OS that support it. Then things really will be WYSIWYG, and a bigger screen will give you more definition, rather than more 'space'
at least 10 years away.
