- 21 Apr 2013
Hi,
My 7970 Ghz edition came today and I have fitted it but my PSU cables wont seem to fit in to the GPU. It needs two 8 pin connectors it looks like, like so :
These are the 8 pin connecters I have but they dont seem to match on a couple holes..
And the other is a split 4pin connector that makes an 8 with the same problem, I also have two 6 pin connectors that actually fit in but that's obviously not going to work.
Am i being incredible stupid here or do I need to buy an adapter or something?
I have a XFX 550w PSU by the way.
Cheers!
Cheers!
You'll only need the one if you already have a 6+2 cable on your psu.
