hi
been doing coding for few weeks at uni now and been going great until now :/
just cant work out what im doing wrong
it is meant to work out how much paint is needed to paint a wall... but at the moment just working out how big the wall is
so it asks for the size of the wall then how many openings.. and calculates the openings
but it keeps coming up with:
but open_total is assigned to 0 at the start of the code?
hope someone can work this out for me
rich
edit:
also if i try to print the value of area i get an error... is it just that you have to do something to get values out of functions?
Code:
def validated_input(prompt):
value = input (prompt)
while value <= 0:
value = input("enter a number greater than zero:")
return value
def wall_size():
hight = validated_input ("how high is the wall? ")
width = validated_input ("how wide is the wall? ")
area = hight * width
def openings():
op_hight = validated_input ("how high is the opening? ")
op_width = validated_input ("how wide is the opening? ")
opening = op_hight * op_width
open_total = open_total + opening
open_total = 0
wall_size()
open_amount = input ("how many openings are there?")
for x in range(1,open_amount+1):
openings()
print open_total
Code:
how high is the wall? 20
how wide is the wall? 20
how many openings are there?1
how high is the opening? 2
how wide is the opening? 2
Error in Python code: Local variable 'open_total' referenced before assignment.
rich
edit:
