Hey guys, installed a tuniq tower on the q6600 G0 version, im idling temps under 40 degrees for all cores which i think is enough, do you gents?
Troule is theres a massive 5 degree difference between the hottest core and the coolest core that seems to stay the same no matter the load, is this safe?
I don't really want to resit the heat sink, (tuniq tower, actual bitch to get on)
So am i good to go for overclocking or will i pop a core?
Edit: the difference seems to increase propertional to the load, running prime95 at stock and hottest is 54; next is 51; then 49 and last is 47.
Thanks guys.
Thanks guys.
