Help with radiator valve
20 Nov 2009
Hi Folks I need a new radiator valve but not sure if the replacement I'm looking at is the right fit.
Can any of you tell if this will be suitable please?
https://www.screwfix.com/p/white-ch...clsrc=aw.ds&dclid=CL_D7tjb4N0CFQI-GwodQ2MCVw#
This is the valve fitting on the radiator...
