hi all i have a 800d case and want to put a 360 rad in the top and a 240 at the bottom will be cooling a gpu in sli/cross fire cpu and mb would like to no what make of rads would you suggest and is this enough rad to keep it cool also after a res and pump combo to save on space what do you guys recommend as i dont no how much on res pump combos as the rig i had before was just cpu and gpu with 2 x 240 rads i had a separate pump to res before but want a res and pump combo for the above reasons as long as there is one up to the job
kind regards
look forward to taking on board your ideas
kind regards
