Help With Ram Speed.
9 May 2009
I recently built my 1st rig, everything is fine i was just wondering how do i check my ram speed, i bought the ocz 1600 but was told that intel boards only see 1333 so i would need to overclock it, i want to double check what it is running at how do i do this? also if i want to overclock the ram how do i do that and is it easy.
Thanks.
yeah ive done that it says its 533 is that correct? i thought it was supposed to be 1600?? or at least 1333?? sorry if thats a stupid question btw.
You double what it says in cpu z not triple it. Because its ddr ram, double data rate. elh_2009 your ram is running 1066mhz at the moment. Standard speed, you don't have to overclock your cpu if you don't want to just increase the memory multiplier and it should have an option to go 1600mhz.
Please dont speak gibberish, it depends on what sort of DDR it is as to whether you dbl or triple or even use the speed quoted, DDR is the speed you see, DDR2 dbl it, DDR3 triple it, as he mentioned 1333 and 1600 speeds I was assuming DDR3, if its reading 533 and its DDR2 then thats 1066, if its DDR3 then its 1600
You are talking about the bandwith not the actual speed of the RAM. The two are quite different. As croogy says, its still DDR but the bandwidth is trippled.
I have a core i7 920 with corsair xms3 DDR3 ram. so how come in cpuz my 1600mhz corsair xms3 ram runs at 800mhz? so your saying its running at 2400mhz? world record speeds? haha somehow i don't think so.
whatever cpuz says your ram speed is, double it. if you have a core i7 put your blk to 200 then your ram should be 1600mhz or 800mhz in cpuz.
It doesn't matter if it's ddr, ddr2, or ddr3. Hell if they make a ddr35, it's still double data rate hence ddr.
Mine says 740 so that's 1480mhz. Croggy has it correct above me. 3x would be a TDR (triple data rate).
DDR3 isnt tripple anything, Take DDR @ 200mhz (DDR400/PC3200), and you'll get 3200 bandwidth, DDR2 @ 400mhz (800DDR2/PC2-6400) and you'll get 6400 bandwidth (twice the chip frequency compared to DDR memory hence twice the datarate as well).
DDR3 on the other hand, at 400mhz (800DDR3/PC3-6400) is exactly the same bandwidth as the DDR2.
The big advantage of DDR3 is the fact that the interface is greatly improved over DDR2, allowing much higher clock speeds, hence 1600-DDR3/PC3-12800, and even faster are possible, while DDR2 pretty much maxes out at 1150/PC2-9600.
They are all 64bit busses (per channel), and they are all double datarate/bandwidth.
The only time tripple comes into play is with an i7, with a tripple channel controller, but with the i7 its not changing the clock speeds or datarate, its simply using a 192bit wide memory bus. But even then you still should get 667mhz displayed with CPU-Z for DDR3-1333.
Memory bus can be as wide as the chip makers desire, hence on graphics cards its often 256bit or even wider, but making the bus wider makes the PCB design much more complex and expensive. Hence the price of X58 boards. The only way to get more bandwidth without the excessive cost of wider and wider busses, would be to go to a serial bus design, but the odds on that happening anytime soon are pretty much zero, as Rambus would jump on any tech development that attempted to use serial designs.
533 means your rams running at 1066, which I believe is the minimum default for an i7. You should be able to change that to get 667 (1333) in CPU-Z without overclocking the CPU, Then as you start overclocking the CPU the memory speed will rise in direct proportion to the overclock. If you have a great cpu which clocks beyond the ability of the memory you then change the ram multi down, so the memory isnt overclocked again etc.
if you want your ram to run at 1600mhz, go into the bios and change the memory multiplier until the memory is running at 1600mhz. If i remember correctly you will have to increase it twice? 2:12? anyone verify that?
how do i do it on cpu-z? if i cant do that ill try croggys way in the bios.
i went into my bios and set it to 1600 and in the memory tab for cpu-z it says DRAM Frequenvy as 800 but in the SPD tab it still says 533 under bandwith? which one should i be looking at?
Ignore what the SPD says, Most SPD's are configured with a wide range of possible settings, but some are programed with "safe mode" so that when the bios tries to auto configure your ram it is most likely to work even on a rubbish motherboard, with a junk powersupply with noisy rails.
The SPD is usefull as a "baseline", but when overclocking, just test for stability with memtest, prime95, and general useage. If it crashes your timings are too tight, or you have pushed the ram a little too far, and then you either up the volts (risky with an I7) loosen the timings, or clock it down again.
800 for Dram frequency in the cpu-z tab is exactly what your after ;)
