Help with rechargeable battery for shaver
20 Nov 2009
Hi Guys
I have a Philishave PT860 shaver which I'm going to replace the battery on.
I'm struggling to find many replacements and wondered if one of you might know?
The only battery I have managed to find so far comes in at £16.00 delivered and the seller feedback isn't so good.
https://www.amazon.co.uk/Replacemen..._product_details#immersive-view_1530973991616
I'll order that if needs be but thought I would post on here in case there was something similar I could pick up for less monies (it's a few years old now so maybe not worth spending that much) :)
Thanks
Nice one thanks mate :)
Just keep in mind that the one you linked has tabs on it, dunno if they're required or not but you can usually McGuyver something quite easily if you can't solder (which is v. easy btw, and cheap and a good skill to have, loads of tutorials on the tube)
Every day is a school day eh lol I'm fine with a soldering iron but wasn't sure about doing this.
I will go ahead and grab a standard 14500 battery and get some tabs soldered on :)
Thanks again.
