- 20 Jul 2006
Motherboard: Asus P5LD2 Revision 2.0
CPU: Pentium D 830 3GHZ
Memory: Crucial Ballistix DDR 2 667 "3,3,3,12"
CPU overclcoked to 3.6GHZ, FSB:240, Mulitplier locked to X15
Memory Speed at DDR2 640, but timings at "5,6,6,18", are the timings bad?, is it safe to reduce them?, option in BIOS to do it but what shall I drop them to, don't want to damage memory.., just want to run memory at near enough stock speed with same timings.., but overclocking CPU makes it tricky..., also anyone know what value for the FSB will give me stock memory speed of 667MHZ?, is it safe to overclock memory beyond that speed, eg..767MHZ?..
OK, just upped memory speed to DDR2 800MHZ, and have timings of 5,4, 4, 15..., but memroy voltage is 1.8v, when it should be 2.2v, so going to sort that out..
