I've recently been told that some of the software we use in UK has been used in a department in Spain, where it failed to work properly, because their regional settings number formats used a comma instead of a dot for the decimal symbol.
Is there a way to find out what they are using in their version of windows, and be able to change it? or at least advise the user to manually change it.
Unfortunately, like most of our software, it's written in VB6, so might not be possible...
