Help with RGB lighting on Phantek Evolv X
30 Mar 2016
Hi guys,
Hope your all well. Ive had this case for ages, and the buttons on the front have never worked, so I just got my new card and thought id try unplugging the leads to see if that fixed it, after reading in the manual its plug n play and where id plugged em in before was for third party lights. Anyway I unplugged one lead, but ive got no response from the buttons on the front of the case apart from being able to turn them off. Its constantly on rainbow. I have a maximus hero xi board, I was just wondering if anyone knows how you get these to work properly?
Ill really appreciate your help
Are you pressing too long?
The manual says you press and hold to turn them off, but suggests a quick jab should cycle between Solid, Breathing, Radar, Sparkle and Rainbow.
I'm a little concerned about the 3rd Party connector, as that is a standard aRGB plug, while the others are Phanteks's own proprietary ones. For that reason, it shouldn't possible to put them into the wrong connectors...
