- 5 Aug 2006
- Derbyshire
Hey all.
My gaming rig is as per my signature.
I have been experiencing bsods on and off, which as I am now using it more for gaming I thought I'd try to fix.
Last night I loaded a saved overclock - I know it isn't quite stable but I'd be running it for many years beforehand.
Now it won't post. I just got a few seconds of power then off. For some reason this has now changed to continuous running. I do not have an internal speaker but the motherboard has LEDs which do not change at all, suggesting problem is with motherboard or CPU.
The PC has done this before but after either mashing reset repeatedly or leaving it it lived with failed overclock message.
I have tried:
A different PSU, but is old and only has 4 pin CPU plug not 8 pin.
Bare motherboard and CPU (no graphics card, ram etc.)
CMOS reset
Removed battery for an hour (doing that now).
One ram stick on its own (thinking I added more ram a year or so ago and never retested overclock).
I am pretty sure I don't need to remove the motherboard due to a short circuit as it has not been removed since new 4 1/2 years ago!
Any help much appreciated!
I have tried:
CMOS reset
