Help with Router please
23 Aug 2005
Cheadle, Cheshire
hi all
i have a Belkin High Speed Mode Wireless Router and two PCs and some cable.... :)
have i gone "over the top" with that router....cause all i wanna do is network the PCs together in the same room....so that both PCs can access each others hard drives and share internet....
can someone point me in the right direction to allow me to do this....
cheers :D
County said:
hi all
cheers :D
Should be straightforward enough dude.
Have you got both PCs connected to the router via Ethernet?
Both running XP?
thanks mate....
the pcs are connected as follows....
one pc is connected to a modem the other is connected to this pc via an ethernet card....
which is rubbish as when pc one is off you cant access the internet via pc two....
have you got msn so you can run it by me or is easy enough on here....
cheers :D
hiya all....
i have set up one of the computers and need another cable for the other but at least its setup....
one bad thing though....
its interfeering with my sky which is picking up via one of those eye things....
aggggghhhhhh....
is there anything i can do or i will sell this router....
if i do sell it which wired router is the best value for money....
cheers :D
County said:
hiya all....
aggggghhhhhh....
cheers :D
I'm funkyt at jumpy dot it if you want to discuss this on MSN :p
It might be worth changing the wireless frequency. Channels 1, 6 and 11 are the most separate (shock horror).
