Hi guys
After a bit of advice.
I have a 1700X, ASrock AB350 AM4 Pro and 16gb DDR4 3200MHz ram and a H60 AIO water cooler.
On auto for the core, the system is stable and boosts to 3.9ghz. my Cinebench score is 1560ish
If I set the multiplier to 3.9 and voltage up to 1.4v, it will pass cinebench but Handbrake encoding or Prime95 results in a system crash.
Any idea what I am doing wrong? On auto what does the voltage run at?
I've tried disabling turbo boost in the bios (core performance boost), voltage set to 1.35 and multiplier set to 39.
OCCT runs for 10 mins then system crashes. CPU temp hits 46C max before crashing.
Any ideas?
Thanks
Any ideas?
Thanks
Time Spy is 9560!
