- 29 Oct 2012
- Skipton, UK
Morning. I've got a 3x4m, 45mm log cabin kit. The instructions are very simple and I've no issues with the construction.
They have provided a box of nails and screws and I'm just unsure which to use where.
The log cabin has 45x70mm floor beams around the perimeter which half lap at the corners.
Between them there are 45x45mm floor joists.
There are t&g floor and roof boards.
It's my understanding that the cabin construction does not use any fixings, even to the roof purling etc.
I have a separate bag of nails which I know of for the separate felt tiles.
The box contains:
1200 2.5mmx60mm small round head nails.
100 6mmx180mm long screws with half shank unthreaded.
50 6mmx100mm long screws with half shank unthreaded.
100 3.5mmx40mm short full thread screws.
Can any one offer some advice? Would massively help me out as the online store is closed weekends.
Thanks. Dan
The box contains:
Thanks. Dan
