- 12 Feb 2006
- Surrey
i'm making a new site which uses jquery slider effect so that all the content is on one page. the content is then fairly simple and very minimalistic which i think is working nicely.
the problem i then have is this is no good for seo point of view, and the fact it can't be linked to.
what i've been doing is have a link at the bottom of each slider to say read more about this service, which links to a static page with more information about the service, better seo/titles etc, and is linkable.
the trouble then comes as if someone then clicks on another service from the static page, do i either have it slide to the same info that you'd see from the normal home page, or have it change the page to the static pages content?
i'm unsure which is best as this creates a lot more work having to make each page static as well as making use of the jquery slider, and also may confuse visitors as the site switches between jquery slider, to no jquery slider.
decided after writing the above the easiest way is to show you how i'd done it and what you all think.
http://www.cleansurrey.co.uk/
you'll see that it's not finished so not all links work etc.
if you click on commercial for instance it goes to a summary page, then say more information link it goes to a static page with more information about commercial cleaning. then if you click residential that goes to static page rather then the summary page.
what do people think? too confusing? is there a better way i could do it?
