Hi
Situation is:
Ubuntu 8.04 with attached WN121T USB wireless antenna
Don't think the WN121T is detected hardware as the little blue light isn't flashing
Netgear DG834N wireless router in the other room
I know the signal works as its OK on a XP setup
Running WPA-PSK security encryption
Have installed the NDIS wireless drivers' through Synaptic - these appear as an item in the system/administration menu - though nothing seems to happen when i run it - or is it running from startup (pretty sure i got some sort of window up once but can't recall what it was about).
Should these drivers work for me with a USB antenna running wireless N??
If i right click on the network connection icon in the system tray i get an option to edit wireless networks (ahh - this opens the NDIS window i mentioned earlier). It doesn't show any info about any wireless network.
If i left click on the network connection icon in the system tray i get an option to "Connect to 802.1x wired network" (i assume this is a wording error and should read 'wireless') - if i click on this i get this screen:
http://picasaweb.google.com/voteslave/OC/photo#5230213985187016130
[How do i show this as a picture rather than a link?]
Most of the fields here mean nothing to me - do they all need to be completed?
Also - will this mean my hardware gets detected?
many thanks
Diss
Situation is:
many thanks
Diss
