Hi All,
Had trouble setting up my home cinema last night. We origanlly had an LG Home cimema which worked fine but was without an optical connection for my XBOX. Because of this I decided to use another home cinema system.
All I did was swapped out the head unit and speakers. Scart socket whch was in our LG was now fitted to our Toshiba.
DVD's and sourround sound work fine, however when I select Line 1 or Line 2 on the DVD remote the Home cinema is unable to pick up the SKY TV signal. As I say, I have not messed around with the wiring setup, I have just unplugged the scart from the old system and fitted to the new.
The Toshiba model is "Toshiba SD-63HK"
Thanks
Thanks
