Help with SFF build please
9 Mar 2004
Hi folks,
I’m looking to build a system for my daughter, and given the space constraints we have I am looking at a SFF build. I have the following requirements
Case no wider than 280mm, depth no more than 450mm
Intel CPU, will not be overclocked
Discrete graphics, Nvidia preferred
Optical disk required
It will be used for a mixture of usual desktop tasks plus some light gaming so storage needs to be reasonable but not massive.
It will be in quite a small space so heat is a concern. Budget £500-600.
I do like the look of the Corsair Obsidian 250D case (as does my daughter) but this could be overkill for the kind of system I’m building here. I also liked the look of the Fractal Design Core 500 but it isnt yet released and I need to finish this build by the middle of next month.
Please let me know what suggestions you might have!
