I'd probably use some m16-m20 threaded rod, bonded into the wall with resin.
There might be heavy duty floating shelf brackets that would be better as my suggestion means having to buy a 16-20mm wood and masonry drill bit, threaded rod and resin. It might work out quite expensive.
