- 7 May 2012
Hi. I'm new to SLI'ing, I recently got another EVGA GTX780 Hydro Copper to pair with my existing one on an Asus Maximus Formula VI m/b. I hacked my existing loop just to get the second card in and working with a single serial connection, and it's currently in and running fine in SLI. But the connection is really only temporary and I'm going to re-do the whole loop so I want to get the cards running parallel. The port spacing between the cards is 40mm - what's the best way to bridge them? I read about 1/2/3-slot flow bridges but I think the distance between the 2 x16 slots on the Formula VI is a bit non-standard. Would the Crystal Link or EK pre-cut acrylic tubes fit? or should I look at the variable length bridges like the Bitspower Aquapipe? There are 2 different lengths listed under the bitspower fittings but I'm not sure either would fit (maybe the larger 41-69mm might be suitable?). sorry if this is rambling.
cheers,
bb
cheers,
bb
