help with some file conversions
16 Dec 2005
Halifax W'Yorkshire
hello there i have some music files which iv copyed from a playstation 1 game called "destruction derby 2"
but the only problem is there .SWP files they play tho on windows media player.. but there over 20mb each one of them :S
is there any way of converting these to .mp3 files at all?
iv googled it and found nothing..
any help would be greatfull thankyou :) (sorry if this is the wrong topic to post it in)
the filenames are normally a lot cleaner, but with compilation discs, they don't come out as clean (because the artist keeps changing)
thats an installer (extractor) for EAC with Lame (to convert to mp3) that i've put together myself, should install fine on 98 to Vista x64
:eek: :eek:
woot! that was fast, i just dragged all of the files bout 300mb of the SWP files into the window, and it did them all in 30 seconds..
i was worried cause they dissapeard and couldnt find them, and there they was all of them as MP3's in my documents :D :D !
thanks mate ;) i owe you
went to my docs? that's weird..
did you drag them into EAC or use the DD2 disc in EAC? (i suggested to use the DD2 disc, didn't know you could drag and drop :) )
