Help with spec please
2 Jun 2007
Bradford
Hi guys, I'm to wanting spec a new tower build with a maximum £500 budget.
Components required:
Case
Mobo
CPU (pref i5)
RAM (8 gig)
PSU
Graphics card
HDD (1 TB)
DVDRW
The PC is for general use. I don't game mutch, but some light gaming would be nice.
Thanks in advance.
Edit: I wont be overclocking.
Thanks for the replies guys, I really appreciate it.
I am going to put Doomedspeed spec into my basket for now. I like the savings on the other components in favour of the better GPU and the style of case is more to my preference.
I'm not going to checkout just yet, so any further suggestions are welcome.
Any suggestions on how I could spend that extra £10?:D
P.S. This will be my first purchase from OcUk, should I be worried? ;)
Thanks again.
Thats good. :)
the only thing Im not sure on the case, not heard much about it, looks pretty basic and should be fine though it may need some more fans. COnsidering its a lot cheaper than most of the other mATX cases it's well worth a try as it may be a bargain. :)
Thanks again.
Fans: :D
YOUR BASKET
2 x BitFenix Spectre Plain BLACK 120mm Fan £5.99 (£11.98)
Total : £11.98 (includes shipping : FREE).
Yes you should be worried, they are addictive, they will take all your money and in return give you boxes of strange electronically goods.. Creepy stuff! :)
Thanks again Doomedspeed, I think I will take a chance on the case you specced, plus the extra fans.
I was looking at a bitfenix case I liked earlier but it was full atx, bottom mounted PSU, 1 single 120mm fan as standard and £33, plus no mesh front to show off my led fans.:D. It had more USB ports but I doubt I will need more than 2.
I've got your original spec in my basket now, plus the fans.
Thanks again.
