help with spec pls
28 Nov 2003
hi
well its time for a long over due upgrade, this is what iv put togetter so far from threads and stuff iv read. The spec is for a gaming and general uses and i want to overclock it as much as i can.
Western Digital Raptor 74GB WD740ADFD 10,000RPM SATA 16MB Cache - OEM
Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - OEM
Asus P5W64-WS Pro Intel 975X (Socket LGA775) PCI-Express DDR2 Motherboard
Akasa Eclipse 62 Aluminium Case - No PSU
AcoustiFan DustProof Quiet 120mm Fan - 3 pin x2
Tuniq Tower 120 CPU Cooler
GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC)
NEC AD7170A 18x18 DVD±RW Dual Layer ReWriter (Black) - OEM x2
HIS ATI Radeon X1950 XT-X ICEQ 3 SILENT Heatpipe 512MB GDDR4 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (RX1950XTX-512)
Corsair HX 620W ATX2.2 Modular SLI Compliant PSU (CMPSU-620HXUK)
NEC MultiSync® LCD20WGX2 20.1" Widescreen LCD Monitor - Black/Silver
Saitek Eclipse 2 Illuminated Keyboard - Blue/Red/Purple
Logitech Cordless G7 Gaming-Grade Laser Mouse - Retail
ok thats the lot my that iv come up with, any advice would be great i just want to make sure i get the right stuff.
thxs
It all looks good, I can't see anything obvious to change anyway other than maybe asking if a Raptor will offer enough space? The only other thing I might suggest is going for an 8800GTS but then that would cost you an extra £50 or so and for the resolutions the monitor is capable of it won't be necessary for a while anyway. :)
thxs fella, i forgot to say that im taking my harddrives from my old rig so the Raptor is just for os and apps. As for the X1950 XT-X i thought it would do till ati bring out there next card dx10 then i can see want to go for ATI or NVIDIA.
