Hey guys,
Im looking to upgrade from my current setup to a new rig for heavy gaming but also for CAD and Photoshop/Web dev.
My current setup is:
MOBO - Asus A8N-E SKT 939 NFORCE 4 AUDIO LAN PCI-Express ATX
CPU - AMD (Venice) Athlon 64 3500+ 939pin 512Kb L2 Cache 90nm Retail Boxed Processor With 3 Year Warranty and Fan Included.
RAM - Geil® Value 2Gb PC3200 Dual Chan DDR Kit (2x1GB) (Cas 3 8-4-4) with Aluminium heat spreader
GFX - Gainward BLISS GeForce 6800 GS Goes Like Hell 512MB GDDR3 TV-Out VGA + DVI PCI-E
PSU - Hiper 525W Triple fan PSU
CASE - ThermalTake Tsunami Black Aluminum (VA3000BWA) +Window c/w 3x case fans +USB2 +Firewire NO PSU
H Disk - Western Digital WD2500KS Caviar SE 250GB 7200RPM SATA2/300 16MB Cache - OEM
CD/DVD RW - LiteOn SHM-165P6S-09C 16x DVD±RW/RAM Int Black - OEM
MONITOR - 19" Sony SDM-S95AB 8ms Black TFT Monitor (3yr onsite warranty)
Im a little confused by xfire/sli, but I would like my new rig to not only be powerful just now, but to be a good baseline for the future
ie. just to buy another gfx for xfire/sli
Im sticking with my case and monitor (for just now), but apart from that, everything else can be changed.
I also run XP64bit, but I will change to Vista if recommended.
Im thinking Q6600 quad, with 8gb ram ...........budget approx £600 (flexible)
Id appreciate any help/advice with this as I can put them together easy enough, but I tend to get lost on all the jargin
Thanks.
Thanks.
