Help With Stablilty
20 Sep 2011
Luton, England
Hi all,
A few days ago the pins on my stock intel cooler fell out and refused to hold, So i decided to use the opportunity to upgrade the cpu cooler. I went with a Corsair H80 (Closed loop water cooler).
Anyway, I figured as It will now run cooler I should have a go at overclocking.
So far Ive hit 4GHZ stable. (It seemed stable)
I ran Intel Burn Test, Heres the results;
Very High 5 Passes (4096MB - 8 Threads);
Took < 3 Mins per run
Average 56.8 GFLOPS
Asus Pc Probe top temp = 67 C
Hw Monitor top temp = 69 C
Maximum 1 Pass (22512MB - 8 Threads):
Took 33.2Mins
Average 52 GFLOPS
Asus Pc Probe top temp = 74 C
Hw Monitor Top Temp = 76 C
Overclock settings;
CPU Ratio = 21
BCLK Freq = 190
DRAM Freq = 1523MHZ
CPU Voltage = 1.29375
QPI = 1.3V
DRAM Bus = 1.65V
(Everything else is Auto)
My questions are
1: Is this a safe OC?
2: How much further should I push it?
3: What else can I change to improve the speed?
Turns out its not stable. Had a crash yesterday, dont really know what for as I had simply left it on (Not doing anything intensive). I down clocked it to 3.7GHZ which seems to be completely stable. However, I would really like to hit 4GHZ. Any help would be much apperciated :D
Computer Specs:
I7 950 @ 4GHZ (For testing) - Corsair H80 Water Cooler
24GB Ram OCZ
GTX 470
Asus X58 Sabertooth Motherboard
OCZ Vertex 2 120GB SSD (Boot)
2 x 2TB Hard drives
Blu Ray Drive
OCZ 650W PSU
NZXT Case (Not full height) 3 x 120mm fans - 1 x 140mm Fan - 1 x 200mm Fan
Is your ram rated for 1600MHz?
You can go a fraction higher on vcore I think, 1.35?
andy.
