Help with system Temps
28 Jan 2009
Gloucestershire
Hi Guys.
I recently bought a GA-MA790XT-UD4P, got my cpu overclocked (AMD X3 720 BE), and am at this minute running it through a Prime95 blend.
http://i142.photobucket.com/albums/r104/SMAndy_85/temps.png
Here's a screenshot of my temps, as shown by Speedfan. I've renamed the ones i know for sure, but the almost middle 3, called "Temp1" "Temp2" and "temp3" evade me.
I'm 100% sure that one of them is the Northbridge... one other could well be the CPU-NB, but I can't figure out which way round they are, nor can i figure out what the other temp is. Temp1 stays around the 35-37 mark, as it is now... I wonder if this is just a diode on the board that is being read as a sensor, since it rarely changes. Could also be ambient case temp, but i doubt its as high as 37°C, unless the sensor is next to my graphics card.
Temp2 is idle at about 40, and temp3 idles at about 35.
Any ideas would be awesome. Also, if you know of any other programs that might help me figure it out...
*edit* just cleaned the dust filter on my intake fans... TEMP1 is still on 37. Temp2 down to 53, Temp3 down to 49, and CPU down to 40. Awesomeness, but I still don't know what they are. None of the heatsinks are incredibly hot to the touch...
