Help with Thaiphoon Burner
30 Jan 2005
Inverness
I want to get the best out of my memory for Ryzen using the DRAM calculator but I can't seem to get Thaiphoon Burner to open.
I've tried running as administrator and compatibility mode but it doesn't seem to open. I'm using a gigabyte AX370M-DSH3 motherboard with 2 x 8GB ballistix 2666mhz
Can anyone offer any advice?
Thanks
Scott
the info given to me by Thaiphoon Burner as never worked or been stable.
if you want help overclocking your ram post up full system spec's here.
I managed to get it on in the end by disabling my anti virus but I was disappointed with the results TBH.
All the DRAM calculator would give me was safe timings as it doesn't have much info for micron B die. I managed to boot into windows and run cinebench at 3200 with looser timings but it was no faster than 2933 with stock timings (and a voltage bump) I'm now stability testing at 3066 with stock timings.
