Hey all.
I've recently moved from on board sound on by Abit AV8 to a hardware soundcard.
I went for this one from OCUK
I'm most likely going to change it as I really need a seperate Mic and Audio Input As i use my XBOX 360 and a Mic for my PC at the same time but ignore that for now.
My current issue is I thought with this card I would have access to the advanced audio settings like I used to have with my SB Live! all those years ago. With this, they're greyed out so I have to use the odd Creative EQ app to get any bass etc.
I was going to sell this one as I need the extra inputs and go for this one
I can see it has the dual inputs but can anyone confirm if i'll have access to those current greyed out options with this card? I dont want to have to install a bunch of audio EQ type apps etc if at all possible.
Thanks in advance.
Thanks in advance.
