Currently have a h100 and although its not bad, theres always better, so started going down my first custom watercooling route.
Specs are:
Thermaltake level 10 GT chassis
I5 2500k currently overclocked to 4.7Ghz
Asrock Extreme7 Gen 3 MB
Currently a nasty radeon 4870 but will be getting a 7970 depending on price etc and would like to WC this too eventually.
Will be selling the h100 so no parts are salvageable from that. I do have 2 x gentle typhoon 1850's already if useable.
Have already bought the OCUK pump and top deal and will be with me tomorrow:
http://www.overclockers.co.uk/showproduct.php?prodid=WC-060-OE&groupid=962&catid=2141&subcat=
Would like a double 5.25" reservoir. Mainly to keep the install tidy and also i love the look of these. Possibly the Koolance RP-452X2 if they ever come
back into stock as it will house the pump nicely.
I think the case is my limiting factor as it will only take a 240 rad at the top and then possibly a 120 at the rear top or base. Suppose i could do this with a hose joining the 2? Bit cramped inside though. I have no kids so the best way for me i think is to get an external 360 rad with some sort of bracket to mount from the top rear 120mm fan. Not quite sure which would be best as i do not want to drill into the case.
Also, are the Ek compression fittings a good choice? http://www.overclockers.co.uk/showproduct.php?prodid=WC-123-EK&groupid=962&catid=1529&subcat=2079
Budget not really an issue, within reason, maybe another £350 ish.
So what would you recommend to complete the install and how.
Specs are:
Any ideas?
