hi all i am building myself a water cool pc at the min i have a 800d case with a 360 rad up top and a 240rad at the bottom the 240 rad at the bottom as a drain port at the opposite end to the inlet outlet i thing its a ek 240 xtc rad i was wondering as that rad drain port is at the lowest part of the loop if it would be possible to connect a ball valve to it and hide it behind the front panel so when it came to changing the water all i would have to to would be to pull off the front panel connect a bit of hose to the ball value and turn it on to drain the water from the loop do you think this would work
