So my housemate had her boyfriend step on her screen, causing several thousand pixels from the top to slowly migrate downward, turning black, like a sickness lol. Still works tho.
So i've found you can get replacement screens for around £80
Its a Satellite U400 PSU40E
I downloaded the manual but it's only the usual one with nothing in-depth about how to take the notebook apart to access the screen.
A shop will charge circa £200 for the same thing.
Anyone done this or anyone know where I can find details to do so?
What connectors are there, data and cold cathode power?
Saving grace is two screws are visible on the lower lid frame and I assume the two others are under the two round rubber closure-shock absorbers.
Thanks to anyone who can help
