Hi guys, my girlfriends car has start making horrid grinding noises when the clutch is engaged (pedal to the floor). It does this at idle and when in neutral and also when you try and pull away.
I'm pretty sure the clutch has gone but would like a second opinion please. When you try and pull away the car try's to stall even though you are giving it plenty of rev's. This leads to it jerking when pulling away.
Sometimes (but not all the time) it is very hard to engage a gear when on the move, i.e. you take it out of one gear and it grinds when you try and select another gear, as if you don't have your foot on the clutch at all.
The weird thing is, the clutch does not appear to be slipping... I have done the usual test of putting the hand break on and trying to pull away. The car pull's fine and does not slip.
So... would a new clutch kit solve this? Mr Clutch have quoted £175 all in, which to be honest I thought was quite reasonable. However, I am tempted to have a go myself as I have help a friend change the box / clutch on an RX7
The car is a Ford 2000 mk5 Fiesta 1.3lt
Any help or advice would be greatly appreciated
