help with tri-view mount
Permabanned
15 Aug 2006
Gainsborough, Lincs, UK
would:
one of these:
http://www.overclockers.co.uk/showproduct.php?prodid=MO-072-SA
and two of these:
http://www.overclockers.co.uk/showproduct.php?prodid=MO-094-SA
work with this:
* Triple desktop or wall mountable LCD monitor brakcet
Tilts folds and rotates
Fits all monitors with VESA 50 75 & 100
Fully Adjustable height
Attaches to any type of desk, thick or thin or the wall
Supports upto 3 x 12kgs / 23" Tv's / Monitors
270 degree rotation
30 degree tilt up and down
The iMOUNT Desktop PRO LCD 006 is ideal for any three LCD TV or PC Monitors between 12" and 17", it will fit all screens with VESA 50 75 or 100.
With LCD monitors getting cheaper and cheaper why not have 3! With this mount you can mount 3 monitors next two each other, increasing both your pc and real desktop space.
Save a huge area of deskspace and improve your posture and productivity!
This handy desktop mount is fully height adjustable so you can now postition your monitors for optimum comfort and reclaim part of your desktop!
Easy to install and supplied with all required fixings.
N.B We also offer mounts that will hold 3 & even 4 monitors, please see our ebay shop for further info.
