Help with TS
4 Sep 2005
London
Hey all
Thought i'd post this in here as i thought i would get better replies.. as pc gamers use TS :p
Basically.. every now and then (mostly when i close/open full screen apps) my voice being transmitted becomes just a fuzz, and nobody else can hear me. I know it isn't the microphone because i try it on local test/sound recorder and it sounds fine to me. The only way to resolve the problem is to close and open TS again... which can be a problem when playing games.
Anybody have any ideas on whats causing this?
Thanks
Sounds like a drivers problem, try updating your drivers or reinstalling your current ones. Have you tried enabling microphone boost, shouldnt make a differnce but might be worth a try.
Yep, i updated them yesterday infact. My sound card is a Sound Blaster Audigy LS. I think its TS though? My mic sounds fine in every other sound recording program :confused:
Could try re installing TS. I've sometimes also found problems with the latest Creative drivers mind. Tried the ones on the disc that came with it?
