Help with UnrealEd...
4 Mar 2006
Wales
Hey guys,
I have recently created a map in UnrealEd for UT2004. The only problem is I can't load it up from within the game, meaning I can't play it with bots, the only method I have of playing oon it is the solo test run contained within the editor. How can I fix this?
Also, when working on it, I saved the map as "blah2" for the sake of it. Now if I try to "Save As" something different I get an odd problem. Within the editor the map under it's new name shows everything it's supposed to, however when I load it up for test, all the pickups are gone. Whats up with that?
Make sure you've set the gametype to deathmatch.
View->LevelProperties->LevelInfo->DefaultGametype - XGame.xDeathMatch
Also, make sure you use the DM- prefix in the map name.
Ah working now.
Thanks a lot :)
(Forgot to call it DM-)
