Help with upgrade please
11 Apr 2004
In Christ
Hi I currently have a AMD X2 6000+, MSI K9A board, 4Gb DDR2 and 4xSata in twin raid.
I'm not really getting on with the board and the chipset so I'm looking for something new.
-I want support for my current CPU and the possibility for upgrade to a X4 later on.
-PCIe2 Support (Crossfire support is not necessary)
-Good clocking options
There doesnt seem to be a huge amount of options out there so Im after some advice and opinions on chipsets and boards, thanks.
If you're looking at getting a new motherboard, you may as well go Intel
Why? Sounds to me like he just wants wants a better board for his current CPU & something a-bit more futuerproof not a complete overhaul!
OP I'd have a look at the new AMD 790GX chipset based mobos. Bit pricey though :(
The Foxconn A7DA-S (790GX) looks really nice and has had positive reviews so far (that I've seen). It would be my choice :)
been using the a7da -s 3.0 for a while now. whilst there are better boards out there based on 790gx, this is a great performer, and i got it for 75 quid - as good £20-25 cheaper than most other high end 790gx's
only thing is that northbridge multiplier adjuster dont seem to work in the bios...
