Purchased a bundle (AMD Threadripper CPU, Asus X399-A MB and 64GB RAM)
The case is a Coolermaster CM 690ii (USB 3).
I've plugged most of it in, but just after some clarification before I finish it off and turn it on.
https://imgur.com/a/UybLiiu
https://imgur.com/a/UNRNWLn
I assume these front pins for case are correctly placed and ok to plug in at the bottom-left of the MB?
https://imgur.com/a/yiMELsl
24 pin, 4 pin and case fan - I assume this is ok - PSU is a Corsair HX650 (I think) modular
https://imgur.com/a/OfvJZtz
Sata
https://imgur.com/a/DCmVasR
Audio, usb, case fan
https://imgur.com/a/h8TfdPn
Overview, needs a tidy and some ties
https://imgur.com/a/bXFp7qh
Already plugged in Audio, is this a duplicate?
https://imgur.com/a/7PGsoey
4 cables
1 is front fan
1 comes off front fan and has two holes - I assume this is for the LED
Red cable, see previous pic, looks like sata - for the connection at the top
White plastic with 2 pins in front
I'm at work now so can't use Imgur, but hopefully the above is a start until I get home
If anyone could point me in the direction of a decent diagram I'd be grateful
Sata
4 cables
1 is front fan
