Help with upgrade
9 Jan 2025
Newcastle
Evening chaps
Looking to see if some one can help me I'm looking to put a new rig together for ets 2 and ats with a current pc I got pretty cheap its specs are
Cpu. Ryzen 5 3600.
Mobo. Rog strix b450f gameing 2
Ram. 16gb Corsair vengeance lpx ddr4 3200
Psu. Evga 600w1
Was thinking of buying an rtx 4060ti 16gb and another 16gb of ram to add to it
But wounder what capability this would give me with monitor sizes while still keeping decent fps and graphics quality
I'm look to go with 3 monitors as big as possible so want to see what this would be capable of before budgeting for monitors or going with a different build
4060 Ti 16GB is unfortunately less capable at higher resolutions than the memory capacity suggests because nvidia kept the same bus width. It can do 1080p very well, but I'd only consider it entry-level for 1440p.
If high res gaming is the priority, I would strongly suggest upping the budget for a card more like the 4070 Super or 7900 GRE, though now is not a good time to buy anything with new cards from AMD and nvidia imminent.
This can give you an idea what to expect:
