Problem is unit is brand new but within 3/4 minutes of connecting with Pc the screen goes black,
power light stays on and blue and I can still faintly see the Pc desktop behind the black which if I turn the power button off then on the screen flashes on, this allows approx 1 second on use before returning to a black screen.
If monitor is switched off for a hour or more when re powered unit stays on again for 3/4 minutes
Pc is a quad core Dell 720 running Vista home.
Also connected my PS3 using the Hdmi cable and monitor stays on for a brief time maybe 30 seconds then turns black ????
I have removed drivers and installed Vista drivers from Viewsonics site
2 disable sleep within windows
2 changed screen resolutions and Mhz
This unit is now on RMA . have i missed something I should have done
Many thanks
D
Many thanks
D
I guess it happens
