Help with Virgin Media and wireless.
18 Oct 2002
I have recently moved into a house with a Virgin Media (NTL) cable box. The box has USB and ethernet sockets and is currently connected to an old PC via the USB connection.
I tried plugging my laptop into the ethernet port but it wouldn't connect. I have since been told that you cannot have both the USB and ethernet connections in use at the same time. True...? (haven't had a chance to test it).
Assuming I can get the ethernet port working in the cable box, what is the simplest way of making the thing wireless? I'm assuming a simple wireless router, I presume my DG834G is useless as this is a modem router...?
Thanks in advance.
Yup, you can only use USB or ethernet with virgin cable modems (and usb is being phased out as it won't cope with higher speeds and is a PITA).
You need a normal cable/dsl router without a built in modem (as opposed to one with a dsl modem built in), so just get something like the linksys wrt54gs or 54gl, reboot the modem with nothing attatched, connect the router via ethernet and you're pretty much away.
